Electric motor for a compressor.
I working on sizing an electric motor to run a reciprocating compressor. We are in the 10kW range at 2000RPM, 45-50Nm. We are looking at frameless motors as they are light weight and have a small profile.
Someone told me that an electric motor will be eaten up by the reciprocating compressor since the torque goes from 50Nm to (-), acting as a brake when some of the air pressure pushes the piston back down.
He says at most it will last a year.
I'm wondering if anyone can confirm or shoot down this train of thought?
RE: Electric motor for a compressor.
I'd say if you correctly apply a new motor, it should last a long time.
There may be some application issues unique to recips that I'm not aware of, but someone should be along shortly to give you a better answer.
Cheers,
Dave
If there were no outlet, then sure, you would have a significant re-expansion of the compressed air. I know it is traditional to have a large, heavy flywheel on a reciprocating compressor which would tend to help with your concern.
A 10 kW machine would surely have multiple cylinders so another piston could more than absorb any "negative torque" produced as a piston goes over TDC.
Keith Cress
Mike Halloran
Pembroke Pines, FL, USA
Bill
"Why not the best?"
Jimmy Carter
