PRO II and Hisys?+
PRO II and Hisys?+
Which is the main difference between hisys and PRO II?
Thanks!
Thanks!
RE: PRO II and Hisys?+
HYSYS sucks because they are way overpriced and they nickel and dime you every chance they get. Not to mention that their customer service is horrable.
PRO II is good for running oil simulations and thats about it.
Promax is way cheaper than HYSYS and provides the most accurate prediction about how plants will perform. As far as their Amine Sweetining, Claus Plant, Glycol Dehydration, and Gas Processing goes they are the best.
And by the way, their customer service is outstanding. If you send them an email it will be answered in about 10min.
Hope this helps if you are in the market for a simulator.
Surprising comment...
juliomendez,
"Which is the main difference between hisys and PRO II?"
Too many differences i.e price, thermodynamic model recommendation, solubility, interface, etc. Don't know which one you think is "main".
JoeWong
Chemical & Process Technology
I've just performed an analysis of multiphase flow for 500 wells into a central system making low RVP crude, and multiple LPG products. I also modeled downhole equailibrium of the crude and gas.
I always add, its not the program its the programmer!!! All sims use the same EOS, Enthalpy, entropy data bases. WinSim has the lagest library of data bases and you can import your own if you don't like the 100 published ones.
thanks
mahao1, please start a new thread if you wish to introduce a new topic.
