rods manufacturing method (except putrusion)
We need to manufacture rods 6mm dia x 1m long, using UD carbon fibre and epoxy.
Is there an alternative way to do this except pultrusion?
RE: rods manufacturing method (except putrusion)
A lot depends on the quantities you need.
A method for small batch work, is to wet preg the roving, draw it through a sizing die to control the resin content, then lay the strands in a mold, close the mold and cure.
A cruder method is to wet the strands on a board, tension wrap them around two pins, then wrap the roving bundles with heat shrink tape, then cure. Leave enough excess to cut off the ends.
B.E.
