Difficulty in understanding PLC 5 Logic
Hello Everybody
I am having difficulty in understanding a logic in PLC 5 and I have attached print outs for the same. Data files D56:15 and D56:16/0 to D56:/3 is triggering outputs O: 014 and O: 015. These outputs are used to transfer set points or other parameter values to a servo controller and according to my understanding it works on BCD coding. I am having difficulty in understanding what we are trying to do in rung 37 and why? In second AND function why "Source B" is having "-16" as value? Displayed value of file N7:32 is in Hex. or in Dec. and why we are dividing it with 16, it says it is bit shift right but how it is shifting?
I would greatly appreciate if somebody can explain these steps in detail.
RE: Difficulty in understanding PLC 5 Logic
I thaught all pages will upload at same time. But here is the pic. for that rung
The final divide by 16, is simply shifting the bits to the right before storing them in D56:15.
So the original data contained 2 numbers in the 16 bits.
bits 1-4 = 1st number
bits 5-16 = 2nd number
