Level to highlight in tree
I was wondering if there is a way to pick a solid in the model and have it highlight in the level tree?
RE: Level to highlight in tree
nope.
Ryno -
I assume you are looking for a way to determine the level number of a particular solid.  You could select Tools/Verify/Entity and pick an entity within the solid.  That will tell you the level of the solid entity and therefore the level of the solid.
Hope that helps.
