surface texture on a shaft
hi!
how can surface texture on a shaft be important?
lets say for a rotating shaft connected to a bearing. How can different surface finish on the shaft affect the shaft/bearing assembly? And in practical/real situations where can that be seen?
many thanks
RE: surface texture on a shaft
Depending on the type of bearing, materials, speed and lubricant the answer will vary. More detail is important.
Ed Danzer
www.danzcoinc.com
www.dehyds.com
hi Ed!
Well, ball bearing, mild steel shaft, lubricant: grease, motor-2850rmp.
