Syncronous Motor
Syncronous Motor
I have a few questions about sychronous motors. I am a Journeyman Meterman by trade and we have some old mechanical meters on our system that use synchronous motors (rotors) as a timing mechanism for demand metering. I know that these are more frequency dependent. I am wondering if I have a 240v rated synch motor how low or high can the voltage be before it has an effect on the speed or performance of the sych motor?
peetey
peetey
RE: Syncronous Motor
There are two types: torque transmitter-receiver and control transformer. Also there is a type with slip ring and other without contact.
See:
htt
In a metering environment with TOU metering these are probably a marriage of an old (synchronous motor) electric clock and a washing machine control.
The timer in a TOU meter must keep the time of day and either mechanically or electrically switch between kWHr registers at definite times of the day.
Bill
"Why not the best?"
Jimmy Carter
It is very interesting, indeed. I remember a kwhmeter provided with 2 kWh registers-one for night hours , for a cheaper kWh, and one for the day hours. But synchronized TOU system it is something new for me.
Many thanks
Best Regards
This would be a synchronous motor clock that keeps time normaly and switches from the day time register to the night time register at the proper time.
Bill
"Why not the best?"
Jimmy Carter
