Can I "Send to Back" using VBA?
In a VBA program, the last item I drew appears on top of an item I drew before that. Is there a way (other than changing the order that I draw them) of sending a LWPolyline to the back?
RE: Can I "Send to Back" using VBA?
Hi jrice174,
Unfortunately, that's not an option in VB/VBA.  You could change the elevation of your lines...
sorry if that's no help
Todd
Thanks for the info. It is appreciated. I changed the order that I drew them and that worked. Have a great day.
Issue ThisDrawing.SendCommand "(ai_draworder ""_b"") " after placing your entity into active selection set.
