Electrical spacing requirements
Does anyone have a table for low voltage spacing requirements in air?  How close can a 3 ampere, 30 volt conductor be to ground?
Thank you!
RE: Electrical spacing requirements
Question does not compute.
An insulated 30V conductor can lay ON the ground. It can be buried under ground...
Keith Cress
For higher voltages search "Creepage and Clearance."
