Adding a feature to and existing array
I have one question...(UGS NX5)
Presume that I make an extrude and make a rectangular or circular array of it... If I will decide to add an additional extrude or something else to that array. Can I do that? And if it is possible...please describe the procedure..
Thank you,
Tadej
RE: Adding a feature to and existing array
yes it is posssible, if you wanted to add another feature, you would need to reorder the feature you want to add to the existing array to ensure that is appears in the history before the array, you can then eddit the array and add the feature, you could also create a group in and add the new feature to the group. If you are using things like blends, you might notice a box that you can tick which says add to all instances, that way you only need to apply the blend to one instanced feature and it will appear on all of the others.
Hope this helps
Best regards
Simon (NX4.0.4.2 MP4 - TCEng 9.1.3.6.c)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but rather how many times it's taken away...
Hope this helps
Best regards
www.jcb.com
Simon,
Almost as easy as adding an extra post to an existing thread wink
