Plastic Steel Design
I hear a lot about ways to design steel beyond the elastic limit with moment redistribution and plastic hinges. Is this something that is easy implemented into general practice? In other words, for those understand these concepts and how to implement them, how much does this knowledge help you a regular basis?
RE: Plastic Steel Design
Both in reinforced concrete and steel design I design to at least nominally plastic (ductility level of 1.25) and more commonly for larger structures a ductility level of 2.
Just as a quick reminder, the ductility level is defined as the ratio of displacement experienced by the structure at ULS to the deflection experienced at onset of inelastic responce.
I would highly recommend learning about these tools no matter where you are, since, even in non-seismic regions moment redistribution can save you from having to go up a size.
Cheers,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
The general provision for designing the moment connections for 25% of the strength usually accommodates moment generated from unbalanced loading. Unbalanced loading, other than the connection has no effect on the member size, hence a general reduction in weight. Also the use of the plastic modulus instead of the section modulus gives approximately a 15% increase in member strength. The continuity also minimises deflections. There are generally fewer pieces to handle further reducing costs. The beams can often span the long cantilever distance.
Dik
The 2 best sources I can immediately give you is an introduction to shakedown by Galambos (free from AISC) and a link to Mastan which is a free program with plastic hinging analysis ability.
http
http://www.mastan2.com/
Thanks for the links. That will give me a good start.
Lyle
Reinforced concrete structures can also be designed plastically by providing sufficient confining steel to permit the beams (or, VERY rarely, columns) to reliably sustain plastic hinge formation. My comment on column plastic hinge formation is because in nearly all structural designs, you want to have weak beams and strong columns to avoid soft-storey effects which can easily lead to premature structural collapse. In very rare circumstances (some bridges, DRE systems, etc) high-precision analysis is used to use hinge formations in columns or infill walls. I do not believe I would be brave enough to design this way, but am aware that it is possible.
Cheers,
YS
B.Eng (Carleton)
Once the system is initially overloaded and unloaded and the first hinges have formed... it is then an elastic system <G>.
Dik
YS
B.Eng (Carleton)
Dik
