Minimum Steel Reinforcement in Retaining Wall
I'm looking for some clarification regarding the exemption for minimum reinforcement given in ACI 318 10.5.3 (allowed where As provided is at least 1/3 greater than required) versus requirements for a minimum spacing of reinforcement steel of 18" in sections 7.6.5 and 14.3.5. This came up in a cast-in-place retaining wall design (relatively small, 10' high). Specifically, I was wondering if you can use the exemption of 10.5.3 to allow for cutting off alternating bars or are you stuck with the 18" max spacing?
RE: Minimum Steel Reinforcement in Retaining Wall
Dinosaur - there are requirements for development that necessarily extend the rebar beyond the point where they're needed, but it's relatively small (6" for #4) so if you truly exceed the 18" limitation, there is some economy in cutting of alternating bars.
Still, I would think the 18" max is there to ensure the reinforcement behaves properly in the system. Otherwise it might be that you have to look at the wall as a structural plain concrete design?
Thanks for your input.
To me, the 18" requirement is a "good practice", rather than mandatory, to prevent wide cracks. Actually, for certain cases, you may need more bars in a closer spacing to achieve that purpose (crack control).
I would never have less primary reinforcement in a slab or wall than was required for shrinkage and temperature. No matter what the minimum area of steel is, you can't exceed a bar spacing of 18" or 3 times the thickness.
I believe that the intent of 10.5.2 and 10.5.3 is for beams, where you could have a concrete section much bigger than needed. A grade beam could be an example of this.
thanks alot
regards
