Variable gain and offset
Can anyone recommend product that will allow electronic analogue signal to be adjusted in gain and offset? Output o to 5v full scale. Input could be anywhere +/- 24 v or -0.5 to + 3 v depending on input device. Current 200 to 10 mA.
Cheaper the better. For R&D work.
RE: Variable gain and offset
Have a look at http://ww
Incidentally, 'cheap' is relative - did you have a figure in mind?
Cheap means less the 30 USD. Now that is cheap.
My solution costs a bit more than that, maybe someone else has some ideas which don't involve making your own circuit? Just bare in mind that developing your own has costs in terms of time you could spend doing something more useful to your employer like R&D on their products, not developing your own circuit! Over here £100 doesn't buy much of an engineer's time. Substitute dollars for pounds and you're about there for the US too.
