Magnetic properties of SS 316
As far as I know stainless steel grade 316 desn't have magnetizability. Is it possible that after welding of pipe weld metal is magnetized?
RE: Magnetic properties of SS 316
If you care about either of these issues then you will have to look at post weld annealing.
Plymouth Tube
"Cold working of austenitic stainless steels can partially transform austenite to martensite. As martensite is "ferromagnetic" this means that austenitic types which would be expected not attract a magnet can show a degree of "pull"."
this is taken from:"Magnetic Properties of Stainless Steel"
http:/
hope this acl help u
S
Corrosion Prevention & Corrosion Control
