importance of surface texture on shaft?
hi!
i would like to know how surface texture is important on a shaft for a shaft-bearing assembly. (i am mostly interested in the practical aspect in real life situations)
i am thinking it has to do with tolerance and mating parts.
and/or retaining the right amount of lubrication for the shaft-bearing assembly in order to perform well.
help me to clarify my thoughts pls.
RE: importance of surface texture on shaft?
Deviations from nominal usually considered 'surface texture' (such as in ASME B46.1) are normally much smaller than the values for overal tolerance variation or even form control. For instance a typical machined roughness of 125 RMS to ASME B46.1, the 125 is micro inches.
It can have a lot to do with friction, as simplistically a rough surface will tend to increase coefficient of friction.
I suggest you do some googling, such as:
http://en.wikipedia.org/wiki/Roughness
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at http://eng-tips.com/market.cfm?
As KENAT pointed out, tolerances are a different order of magnitude: tenths rather than micro-inches.
Don
Kansas City
KENAT,
If the surface lay has a 'threaded' finish it will pull lubrication out of the shaft-to-bearing running clearance. Plunge grinding will create a preferred circular lay instead of the helical lay of a travel grind.
Ted
page 2 - specifications for hard working journal bearings.
page 24-25 - bad things that can happen if the polishing is done in the wrong direction.
