stator on the oven... trend
hi, i had read in a manual (Marelli generators, Italy) that they talk about generators heating to take out humidity on the oven, and you´ll see a trend... and recomendations, in example, measurements of isolation each hour... and you´ll see, the trend of insulation rise and after some time decrease... and then rise again to the final and stable point.... why this trend? and why to cheek insulation each hour?
RE: stator on the oven... trend
As for that particular trend? Someone else will have to say.
Keith Cress
http
