Iges files from vendor opens in wrong scale
When I download an iges file (the only format offered) from a vendor, the scale isn't correct. It is in inch units instead of millimeters which means it's 25.4 times larger that it should be. Is there any way to rescale the part or is there some setting in Inventor that will clear this up?
RE: Iges files from vendor opens in wrong scale
David
25.4 for inches into mm
.0369 for mm into inches
