Member Login
HANDLE
PASSWORD
Remember Me
Forgot Password?
E-mail*
Handle
Password
Verify P'word
Partner With Us!
Partner Button
(Download This Button Today!)
Member Feedback
"...This was the ONLY place that I could find information that I could use to resolve the problem. So thanks once again to member TomSark and the SQL forum!..."
Geography
zakk (Mechanical)
7 May 02 17:12
This may be simplistic but here it goes anyway... I am designing a screw jack and need to have some idea of the typical amount of force a typical human (male 170 lbs) can comfortably exert on a wrench to turn a bolt.  By comfortably, I mean without bouncing or sharply jerking the wrench.  This force should be independant of the length of the wrench or size of bolt.  I realize human strength varies widely, that is why I indicated 'typical'.
Thanks in advance.
Check Out Our Whitepaper Library. Click Here.
dlew (Structural)
7 May 02 19:46
zakk,
I think a construction worker could apply easily a force of 100 lbs. provided he has enough room and a good point to react.   If he can not, he always can use a longer wrench.
AEF
Islander (Mechanical)
8 May 02 0:31
why not just try out a couple of torque wrenches of different sizes.
Helpful Member!vonlueke (Structural)
8 May 02 2:46
zakk:  Assuming little body anchorage, I'd currently estimate a typical value of 170 N (38 lbf).
svanels (Petroleum)
8 May 02 21:05
Using one hand, height at 22-42" the force is 66-83 lbf
2 hands would give a maximum of 165 lbf
Steven van Els
SAvanEls@cq-link.sr
MadMango (Mechanical)
8 May 02 21:10
I work with ADA (Americans with Disabilities) Standards, and there is one requirement that may help get you in some sort of ergonomics ballpark.  The requirement states that any manual operation of a vehicular wheelchair lift shall not exceed 50lbs of force.  50lbs isn't much to your normal male, but average females (~5'-4" ~110lbs) find it on the edge of "hard to move".
"Happy the Hare at morning for she is ignorant to the Hunter's waking thoughts."
DesignControl (Mechanical)
8 May 02 23:05
I believe that there are two factors that you need to consider:
1.  Pain threashold -- the area of the wrech at the applied force will effect the tolerable pressure experienced by the operator.
2.  The proper use of a wrench involves torque, which implies a force couple -- both hands should be used to generate forces in opposite directions, otherwise your knuckles suffer.
DesignControl
Hush (Mechanical)
9 May 02 10:41
Your local occupational health & safety office or workers compensation office should be able to provide you guidelines. Failing that, try to find yourself a good industrial ergonomics text or handbook, if there is such a thing.
gunnarhole (Mechanical)
9 May 02 17:38
Zakk,
In appendix S of the ASME Section VIII pressure vessel code there is an equation given that estimates the stress developed in a manually tightened bolt/stud, using standard wrenches as:
Stress, psi = 45,000/[(bolt nominal diameter, inches)^0.5]
we can estimate that
Torque, in-lbf = CoF * Stress * bolt dia^3 * 0.785
where CoF is the coefficient of friction (I usually use 0.17)
we know that
Torque = Force, lbf * radius, inches
so given a standard wrench length you should be able to estimate the force.  Remember that this is all based on tightened torque.  This may be a little more torque than you want to allow over the full range of the lift, but it will give you some insight into a statistically determined upper limit.
Gunnar
MikeMech (Mechanical)
19 May 02 23:43
When I used to design equipment for commercial and military ships, they usually specified a maximum of 50 lbf exerted by a human for normal operation of the equipment.
I've seen this max. value for equipment in the industrial sector as well.
Start A New Thread
Promoting, selling, recruiting and student posting
are not allowed in the forums.
Posting Policies
LINK TO THIS FORUM!
(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Mechanical engineering other topics Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=404
DESCRIPTION: Mechanical engineering other topics technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
