Heat and condensate generation
I want to calculate heat and condensate generated during compression of 4000 nm3/hr atm. air to 3.0 kg/cm2. We are using 2 stage centrifugal compressor.
Thanks.
RE: Heat and condensate generation
I will try to stop anyone preventing you of doing those legitimate calcs you wish to complete. Please advise also if you need any help with those calculations.
cheers,
gr2vessels
