Physical simulation of bag sealing?
Ok, I'm pretty sure I know the answer to this but I figured I'd ask anyway.
Let's say you have a mechanical bag sealer and you want to animate the spool of plastic being fed through the sealer, filled with product, then sealed (which would, essentially, crimp it), then cut off. Make sense? Any ideas?
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
RE: Physical simulation of bag sealing?
Can you create different config's and have animator start each config at different times?
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Thanks!
