Needed: Circuit for Signal Generator 75W Oscillates at 100Ghz-200Ghz
I am devising an experiment that requires a 75W signal generator in the 100GHz-200GHz range. I am interested in the resonance effects in this region. Could someone please advise me on the circuit design and materials required for shielding for such a signal generator and related safety issues for this design construction. Thanks...
RE: Needed: Circuit for Signal Generator 75W Oscillates at 100Ghz-200Ghz
Google 'Active Denial System' for an example of 94 GHz in action.
That's alot of power. Solid state can't get close to that. That can only be a very expensive TWT amplifier or group of TWT's combined with a waveguide power combiner.
Guessing $lots of money.
Here's one reference.
The goal of this program was a TWT (double comb delay line structure) in the 94-GHz frequency range with an instantaneous bandwidth greater than 500 MHz (tunable within 1 GHz) and an output peak power greater than 200 W in the center of the band (150 W over the band) for a duty cycle of max.
kch
