[Excel] Using the Find method
I hate to ask these kind of questions, but...  why doesn't this work?  I'm getting a compile error on the Set dtFindMe line.
Sub FindDate()
  Dim dtFindMe As Date
  Dim rgFoundMe As Range
  Set dtFindMe = DateSerial(2002, 2, 22)
  Set rgFoundMe = Range("A:A").Find(what:=dtFindMe)
  If rgFoundMe Is Nothing Then
    Exit Sub
  End If
  rgFoundMe.Font.Bold = True
End Sub
Any help would be appreciated.
SM
RE: [Excel] Using the Find method
DateSerial returns a Variant and you only need to use the Set statement for objects, not variables.
  dtFindMe = CDate(DateSerial(2002, 2, 22))
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
Does, then, the following line not need its Set?  Or is a range not an object?
SM
Yes, the Find method returns a Range object, so it would require the set statement.
The code works in this variant:
    Exit Sub
  End If
End Sub
dtFindMe it is not an object and you do not have to use "Set". !!
