Modification of Pressure Fittings?
We plan to modify some standard pipe fittings by drilling holes through the wall of the fitting. One example is to drill and tap a 1/8"FNPT hole through the wall of a 1.5" to 1" reducer fitting.
What would be a good code for testing these modified fittings? I have looked through ASME B31.3 and found no section on modified fittings and testing criteria.
RE: Modification of Pressure Fittings?
