Point, coordinate, layer in Autocad
Hi all,
Is it possible to import a TXT file in AutoCad with the following header:
<PntId> <Noth> <East> <Height> <Code>
in such a way that it draws a point at the specified location and assigns this point to a layer <Code>
Or a script could solve the problem?
Any hint how to do it? or could you point me out to some explanations?
Thank you in advance.
RE: Point, coordinate, layer in Autocad
sure.  use Lisp or VBA to open and parse the file.  Or, create the text file so that it says layer set code point x,y,z and add the extension scr to the file then invoke it using the script command.
layer set code
point x,y,z
layer set code
point x,y,z
etc
thread 159-230306 may help
