HDPE pipeline
HDPE pipeline
HDPE pipeline
Hi
I will use HDPE material for a pipeline of 6"@250 psi/ 20C.
Everyone have this experience?
Maybe someone will hve some ideas?
Patinina
RE: HDPE pipeline
How do you guarantee that a pipeline stays at 20C?
Mike Halloran
Pembroke Pines, FL, USA
RE: HDPE pipeline
Thank you S Jones,
I picked up
HDPE PE 4710/ 250 psi@ 20C
with B31.3 fittings andsome plastic fittings.
I need sleeve on for corrosion protection/ fabricated fittings/ O-rings etc.
Suplier:
Global Polly Systems
Fittings from
www.hawkeye.com
However I had to go for 8 -1 0" pipeline.
Mike:
The material is designed to work at this temperature nd it goes max 60C( I never like to pick the mx temp).
The working conditions/ flow raate etc re exactly like for steel pipe.
The difference is in corrosion- much less, but again some points are subject to leak.
Patinina
Corrosion & Materials Engineer/ SpecMan - Spec Writter
