Power Transformers with OFAF rating & % Impedance Volts
Power Transformer impedance volts is specified at rated kVA rating as per IEC60076.
Rated kVA corresponds to OFAF rating when the transformer is equipped with multi-cooling.
Is this correct or should the impedance rating correspond to base rating of the transformer (ONAN).
Thanks.
Thanks.
RE: Power Transformers with OFAF rating & % Impedance Volts
Marmite
My understanding and experience is that IEC impedance is based on the highest forced-cooled rating of the transformer. But there may be exceptions to this, so you should verify.
This is generally spelled out on the nameplate.
However, best way is to go through OEM factory test results / documentation and get absolute value and then use it.
NC
Can you explain that a little more clearly? The ohmic impedance of the transformer doesn't change with either cooling method so, glancing at an SLD in front of me for some typical values, a 24/48MVA ONAN/ODAF transformer has an impedance of 9% on the 24MVA base and 18% on the 48MVA base. Either pair of values would yield the same results in a fault level study, so I can't see why it would be advantageous to use the OFAF value in calculations.
"My understanding and experience is that IEC impedance is based on the highest forced-cooled rating of the transformer."
Thanks. I too think so. But my serach of IEC 60076 didn't yield any fruitful result. I am looking for help/confirmation.
Thanks to you too, dpc. Your memory must be great.
