Re use of plans
Re use of plans
Re use of plans
I have designed a pressure treated wood foundation for a house for a client. He now wants to use the drawings to build 20 more houses using the same plans. My fee was $500 for the initial structural drawings. The houses are all to be built in the same subdivision.What do you think would be a reasonable fee for each of the projects.
RE: Re use of plans
1/2 your original fee, but in any case check with your insurance provider!
Cheers,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
RE: Re use of plans
and the original fee for any prototype changes
RE: Re use of plans
For a PWF foundation, your initial fee of $500 seems pretty low... You might check around and see what the normal cost for this work would be.
$250 for engineered PWF plans seems to be very low.
Dik
RE: Re use of plans
I agree with 50% - but $500 for the initial job seems low....
RE: Re use of plans
If he didn't provide the drafting, and the house is small and regular in plan, I don't see $500.00 (before taxes and expenses) as wholly unreasonable.  That said, I do not know the US market...
I would think a small residential job would have been a few hours to design and an additional one half to check.  Add in an hour for client liason and checking the drawing, I' call it a four hour job.
But you're all quite right; It's unlikely that the job was this straight forward...  I'd like to hear a responce from the OP!
Cheers,
YS
B.Eng (Carleton)
