What do System Engineers do?
Anyone with Mechanical Engineering background becomes
System Engineer in thier respected field? What do System Engineers do?
How does a System Engineer differ from a Project Engineer?
RE: What do System Engineers do?
Systems engineering is a field of engineering. I would have thought google would come in handy.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
I would hope that "Project" meant bean counting, whereas "System" meant engineering interaction. I'd certainly check the meaning before signing on the line.
- Steve
As system engineer is responsible for engineering of the system.
If your project is a system...
In the upper reaches of management of military projects you can see giant Gantt charts with all the paths indicated. It is the ultimate example of project management. It is more management than engineering, but the system engineer needs to talk engineering to many engineering players.
My question is if any of you have gone to similar path and would like to share your experience and where did it take you?, where have you gone outside engineering field to apply your System Engineering skills?
Thank you
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Since my work is largely in a field where the product is very well defined, and has a hundred year old structure, I don't get to do much Systems Engineering, other than the dreaded FMEAs.
I suspect in most organisations there is a big difference between project engineer, and project management.
Cheers
Greg Locock
In my specific case, some understanding of ME, EE, CS, physics, etc. is required.
TTFN
At university the course pretty much focused on giving us a basic understanding of all the typical major systems of an aircraft, with the goal of being able to lead the integration of all these systems. Simplisitically speaking to get the experts on each different system/discipline to talk to each other.
However, in industry it can have many different definitions. I'd ask for a detail job description of the specific position.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at http://eng-tips.com/market.cfm?
