Air actuated slide gate
I'm going to a site that has an air actuated slide gate tomorrow. The gate has a lubricator on it and the manual says to ensure that there is enough lubricant present. But, it doesn't say what to use as lubricant. I assume some type of oil, but can anyone help me out further?
Our vendor is closed for the weekend so I cannot contact him directly.
RE: Air actuated slide gate
Unless you can determine approx what you are looking for, its tough to make recommendations.
Here is what we use.
We have numerous slide gate valves that use both grease and
oil. The ones that use oil we normally use a 100 sec water resistant oil. The grease we use is an NLG2 again we use a water resistant grease.
We use Lubrication Products for all conditions where moisture might be problem,
http://www.le-inc.com/
It's a Meyer slide gate.
