120 from 1ph 230
120 from 1ph 230
Is it 'illegal' to take one leg of incoming 230v single phase and ground to energize a 120v motor contactor coil to switch a 230v motor?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: 120 from 1ph 230
Some of this information is based on a real event, where a circulating current through a safety ground system for a transmission line "Baked" the surrounding earth. A worker was lifted by a crane, in a work basket. The crane was grounded to a different ground rod. When the worker touched the grounded power line, the difference in voltages between the two ground systems knocked him unconscious. You are attempting to generate a similar situation.
Please don'tIt is a condition that gets worse over time. No telling how much time, minutes, hours or days. It may work at first, but you may come back later to find yourself dead.
Bill
"Why not the best?"
Jimmy Carter
