From developed surface of a cylinder to the cylinder-any technique?
Pals
I have a complicated pattern to be applied on the face of a cylinder.
I can develop the pattern on the surface with simple math
I drew it as on a plane, a cool developed pattern on a rectangular surface of course.
Now I would like to turn this surface from a plane surface to a surface of a cylinder.
Tough to do using math
Has autocad such utility? or anyone know of a handy technique to work from a developed surface into real surface, at least for a cylinder?
Note that I am not projecting my pattern onto a cylindrical surface, I am simply wrapping it as it is around the cylinder whose diameter is known.
It is a wrapping issue
respects
IJR
respects
IJR
RE: From developed surface of a cylinder to the cylinder-any technique?
I know Rhinoceros can unwrap a cylinder, and I >think< it can go the other way, too.
Mike Halloran
Pembroke Pines, FL, USA
