NX 3.0: GM DCS File Log Macro for Batch Execution
Subject: NX 3.0 General Motors Toolkit - DCS File Log
How can I extract the DCS File Log from multiple parts using the General Motors Toolkit? I know how to do them individually, but I want to be able to extract and save the logs from multiple part files in a single step.
RE: NX 3.0: GM DCS File Log Macro for Batch Execution
Within the toolkit directories, you can open some of the .dat files (I think .dat....maybe another file type) with Notepad or any text editor and within those files are usually contact phone numbers for the actual programmers of the toolkit. They MIGHT assist you in figuring out a way to do what you're wanting, if they're even still employed by GM.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
Upon learning that, I have been playing around with Tools --> Macros within UG and have managed to create a macro to save the Log from the current part. The next problem to solve is that I can't figure out how to get the Macro to read the part number of the active file in order to save the Log file with the same filename.
I am thinking that it should be possible to create a batch file that would:
1) Create a variable out of the file name,
2) Remotely start the UG .prt file,
3) Execute the Macro and save the Log using a blanket filename
4) Close the .prt file,
5) Re-name the log using the file name variable,
6) Repeat this process with the next .prt file in the target directory.
It's a work in progress.
GEES is always a dead end unless you have a question about the way the toolkit operates as it is. In order to get help with the guts of the toolkit, you'll have to find a way to get in touch with the people that actually wrote the programs in the toolkit.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
The New DCS is based on Knowledge Fusion, so that will be a little different extracting the information.
-Dave Tolsma
http://Tolsnet.com/jobs
http://groups.google.com/group/NX_CAX/
http://groups.google.com/group/plm-exchange/
Could a macro or a Journal capture those clicks and be repeatable. If so then it is a matter of building code to open a list of files and output the contents, that is a little harder but quite possibly there are similar programs available that you could adapt to your needs.
One thing though GM use Teamcenter so it would make critical difference to know whether you're running this as a client of their database or in Native mode.
Cheers
Hudson
The problem I'm currently having is that when you launch the GM toolkit version of UG, you do that from within a sub-menu. I have found that I can launch normal UG (without the GM toolkit) using the command:
"C:\Program Files\UGS\NX 3.0\UGII\ugii.bat" -retrieve:filename.prt -key:Print_DCS_Log_File.macro
This launches UG and executes the macro. Unfortunately, the icon to display and print the log file doesn't exist in normal UG so the macro fails. What I need is a method to open a list of parts using an existing GM Toolkit UG session or a method of launching GM Toolkit UG without having to go through the menu.
