upgrading to 2008 SP4 removed my colors
Hello all,
I upgraded to 2008 SP4 after using SP0, and it removes all the colors set to the part, on the part level and the assembly level.
I think its a settings issue but i cant change it, can you help me.
Now if i go to Edit>Appearance> color is not on so i cant click on it and i can only click on RV appearance, sometimes Material as well.
RE: upgrading to 2008 SP4 removed my colors
But it is true that everything turned gray, on th part but the background are the same as before the upgarde.
someparts still have their colors but others truned gray.
What do you recommend?
regards
maybe its something with the video card settings coz i add another monitor yesterday.
regards
I can not see how the 2nd monitor would mess this up on you. I agree with your guess that some check box in SW either got checked or unchecked in the upgrade process.
