Parts list not showing item number
I have a drawing of an assembly where the parts list is not showing the item number.  Originally, this was working before I put the assy into Teamcenter.  Now, the item numbers will not show.  The ballons do not have item numbers either.
Suggestions?  NX5
Thanks..
Fighter Pilot
Manufacturing Engineer
RE: Parts list not showing item number
If it only happens on one part some of the settings below may assist.
Has it got an item number column with the value set to "Callout". There's no reason to accidentally change this but if it isn't present then a parts list won't work.
Also you could check that your levels are set correctly. It is perhaps a little more like a couple of wrong click could cause you to have certain problems. I would suggest that before you change anything open a part with the parts list set up correctly so that you can check and copy the correct settings.
If it happens on all parts you could check the customer defaults as suggested, but I know of nothing that would disable this functionality as dramatically as you appear to describe.
Cheers
Hudson
