Saturated vapor pressures of water
Hi all,
I have a question regarding the saturated vapor pressures inside a compressor dryer working at 8 bar(a).
For a calculation I need to know the satured vapor pressures of water at a temperature of 150 °C. I cannot find those numbers in tables in literature. They all stop at 100°C, which is logic otherwise you could have relative humidity higher than 100%.
If I have a dryer working at 8 bar(a) and a regeneration temperature of 150 °C, than I CAN have a relative humidity between 0 and 100 %, depending on the absulute moisture content in the air.
Is there a way to calculate the vapor pressures at these temperatures and pressures?
Many thanks in advance.
Sherpa
Sherpa
RE: Saturated vapor pressures of water
Best regards
Morten
best regards
Morten
Best regards,
Sherpa
4.76÷8 = 0.595 = 59.5% moisture in the vapor
Its not easy to calculate saturated water vapour pressure - use a table.
If you wish to calculate the %humidity for a superheated steam then you must calculate the water content at your boiling point for the actual pressure and then at the superheated temperature and thats the relationship.
Just rememeber that if you got a "pot" boiling at atm. pressure it cant be any hotter than 100 deg C. If you wish to superheat it that must take place "downstream" the pot.
If this is serious work then i think its about time that you contact somebody who knows about steam - and fork out the consultancy fee if its not in-house.
Best regards
Morten
Thank you all for the input.
I found some interesting formulas in the 2005 ASHRRAE Handbook to calculate saturated vapor pressure in ranges from -100°C - 200°C.
I was just wondering if the working pressure of 8 bar would have an influence on this vapor pressure, but it seems to me that only the temperature of the water vapor has importance.
When you have water vapor at 8 bar and a temperature of 150°C, I don't think one can speak of steam, or am I wrong? At 8 bar, water starts to boil at +- 171°C.
So my ultimate question is: is it correct to say that the (saturated) vapor pressure does not change when pressured is raised. Total pressure would be:
P(total = 8 bar) = P(air) + P(water vapor)
So as long as I don't form steam, I can use vapor pressures.
Many thanks for all the replies.
Sherpa
However i get the feeling that you may need more direct consultation with somebody how know this subject than what you can get here if this is used professionally.
Best regards
Morten
