pattern edge flange
pattern edge flange
I am trying to pattern a couple of edge flanges from a part I drew, I am able to pattern a cut extrusion but it does not allow me to pattern the flanges
can this be done?
I am using SW2007
Thanks for your help
Ricardo
can this be done?
I am using SW2007
Ricardo
RE: pattern edge flange
Flores
Diego
how about this instead, can you pattern a jog?
I tried it but it did not let me either (now, I would do it if there were only 5 tabs or so, but my part has about 50 and talk about a waste of time trying to draw each one individually)
Thanks for your replies
Ricardo
But first, submit an ER.
There is your answer... do not pattern the flange, pattern the cut. I don't have a clue what your are building, but the principal is the same; make 1 long flange, add 1 cut, and pattern the cut:
h
Flores
I could not do it using the sheet metal portion, I had to do extrusion and cut extrude the two flanges that form the punch, then I had to insert a bed so it would flatten the punch
Thanks everyone for all your input
Ricardo
