Load Combination for Hydrostatic Uplift
I have a 20' deep concrete tank, buried 15' into the ground.
Flood elevation is 3' above the ground (non-coastal A-zone), what load would be used for determining bouyancy for the tank?
ASCE 7-05 2.2 defines H as "load due to lateral earth pressure , ground water pressure or pressure of bulk materials(note the comma)." So maybe the bouyancy force is H.
However the commentary suggests H is due to lateral pressure due to soil and water in soil..". The bouyancy force is not lateral, so maybe it is not H, but actually Fa (flood load). There's a big difference in the load factor (1.6 vs. 1.0)!
What if it is just ground water and not flood water??? Back to H? F (fluid load) doesn't see appropriate...
Any opinions out there?
RE: Load Combination for Hydrostatic Uplift
