draft a surface?
draft a surface?
is it possible to draft a surface in catia? (i know about drafting solids). so far i've been creating my surface, adding thickness (turning it into a solid), drafting it, then extracting the surfaces. there has to be an easier way....
anyone?
thanks
anyone?
thanks
RE: draft a surface?
Drafting surfaces, 3D lines, splines, planes, surfaces cut solids is really tricky in Catia.
