Doube Angle Column Intermediate Connectors
The Table 4-8 (double angles in axial compression) in the AISC 13th addition steel manual gives the number of connectors needed between angles. Can somebody explain to me why the number of connector say for like a 2LL6x6 column is 2 no matter if you have a 2' long column or a 40' column???
RE: Doube Angle Column Intermediate Connectors
