Macro to labe an XY scatter plot
As far as I know there is no way to label each point in a XY scatter plot. Has anyone come across a macro that can do this? or any other means?
Mike
RE: Macro to labe an XY scatter plot
what kind of label are we talking?
x value
y value?
x, y pair?
other text?
I mean a data label for each point on the XY scatter plot extracted from a third column containing the labels.
This label would be a text
Never mind.......This macro I found works for me,
Sub LabelPoints()
ActiveSheet.ChartObjects("Chart 1").Activate
ActiveChart.ChartArea.Select
Dim myXValues As Range
Dim myYValues As Range
Dim myNameValues As Range
Set myXValues = Application.InputBox(prompt:="Range of X Values?", Type:=8)
Set myYValues = Application.InputBox(prompt:="Range of Y Values?", Type:=8)
Set myNameValues = Application.InputBox(prompt:="Range of Labels?", Type:=8)
For i = 1 To 20
ActiveChart.SeriesCollection.NewSeries
ActiveChart.SeriesCollection(i).XValues = myXValues(i)
ActiveChart.SeriesCollection(i).Values = myYValues(i)
ActiveChart.SeriesCollection(i).Name = myNameValues(i)
ActiveChart.SeriesCollection(i).Select
With Selection.Border
.Weight = xlHairline
.LineStyle = xlNone
End With
With Selection
.MarkerBackgroundColorIndex = 25
.MarkerForegroundColorIndex = 25
.MarkerStyle = xlDiamond
.Smooth = False
.MarkerSize = 5
.Shadow = False
End With
Next
End Sub
Mike
