How do you use SW to calculate forces?
How do I set up to calculate the force required to "Coin" a shape into a piece of 1008 steel?
RE: How do you use SW to calculate forces?
I really don't think you can.  You might be able to do it with the full version of Cosmos, but even then I sort of doubt it.  You might be able to use SW to help calculate some geometry, but not forces.
-handleman, CSWP (The new, easy test)
Blankworks.
