Creating a plane through points
What is the best method to create a plane that is a best fit through a number of points.
Currently, I am using the Surface from Point Cloud feature and specifying a U and V degree of 1. Then I place a plane on this surface. However, the Surface from Point Cloud is limited because you cannot edit the paramters after creation. I'm not sure if it is associative either.
NX 5.0.4.1
NX 5.0.4.1
RE: Creating a plane through points
As you may know any three points will create a plane, for more than three it is possible for some to be off the plane. Your cloud of points method would be as good a method as any, provided that you set the U and V degree and patches both to 1 then it will generate a planar face.
Cheers
Hudson
