Air Separation Unit
Air Separation Unit
Air Separation Unit
I  have information on an existing ASU inland at a barometric pressure level of 0.86 bara at a specific oxygen purity and producing 3000t/d of oxygen.  I also have the cost of such a unit assume x million $.
I need to move this ASU to the coast where the barometric pressure is 1 bara and it must still produce 3000t/d of oxygen.  How do I determine this effect on the cost estimate.  Yes the MAC will change in size but how does one do it again?
RE: Air Separation Unit
your inlet compressors will be what dictates throughput.  They will push more volume at a higher pressure and will need more HP.  You could put a screen on the inlet to artificially reduce pressure.  My concern would be water content, dry inland, humid coast.
