Spring OD Expansion Measurement and Calculation
How you would measure compressed spring outer diameter? The spring free length is 0.150". OD at free length is 0.120". Wire diameter is 0.060". ID is 0.100". Material is stainless steel. I would like to compress the spring at 0.050" and measure the OD expansion. What would be an accurate way to measure the OD at compressed state? Is there an equation that I can use to calculate the OD expansion?
RE: Spring OD Expansion Measurement and Calculation
http://www
htt
