Solutions used for electropolishing of Stainless Steel
Can somebody explain what is meant by plating a prepared solution, and how it is done?
Solutions used for electropolishing of Stainless SteelSolutions used for electropolishing of Stainless Steel(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Solutions used for electropolishing of Stainless Steel
Typical solutions use sulfuric and/or phosphoric acid electrolytes at somewhat elevated temperatures (>100 F) at widely varying current densities (from 20 Amps/square foot to 1000 A/sq. ft).
A good article with more details was authored by Kenneth B. Hensel in the January 2000 issue of Metal Finishing (Volume 98, Issue 1, pp. 440-448). Kenneth works for Electro Polish Systems in Milwaukee, WI, USA. A link to their website is included below:
http://www.ep-systems.com/index.html
If you need some other information, please post the question again. Good luck.
Thanks for your answer and sorry for the confusion. I already know the electrolyte mixture and it is as you say plus the addition of a propriety material. However, I have been told that after mixing in the right proportions ( which is no problem) the electrolyte has to be "plated In" with stainless steel and the solution should be fully worked to a minimum of 30g/l iron,nickel or steel content.
I presume this means that I should use the solution at a low current flow until this is achieved. Am I right?
