Large tapped hole sizes in hole wizard?
How can I use hole wizard to insert over 3" dia tapped holes?
I'm using ANSI in.
I'm using ANSI in.
60% of the time, it works every time.
RE: Large tapped hole sizes in hole wizard?
-handleman, CSWP (The new, easy test)
