Short range remote.
Short range remote.
I'm considering a product that would need to be completely cordless. It needs to be controllable over a distance of about 30ft. Bi-directional info would be preferred but not absolutely required. Low data rates. Perhaps 300baud would be plenty.
The control unit would be like a typical TV remote. Perhaps smaller.
I really don't want to 'scratch build' the rf stuff nor do the full FCC Monty.
What tech and frequency should I be contemplating?
ISM no doubt, but which.
Got any favorites?
Got any favorites?
Keith Cress
RE: Short range remote.
Glenn
Dan - Owner
http://www.Hi-TecDesigns.com
VE1BLL; Yes that might make more sense.
geekEE; Thanks for the link. Looks interesting. It could go international but I'm not sure. I'm a little concerned the 2.4 region is way crowded and could result in issues with phones, et al.
Keith Cress
ht
I think the worldwide compliance is one reason that Bluetooth is in that band.
I haven't seen any issues with the Nordic part behaving badly with other 2.4GHz devices. It does some sort of frequency hopping to avoid this. And also, since it's bidirectional communication, you can have ACKs coming back to have a pretty bulletproof comm link.
Glenn
Any experience with how 2.4GHz will punch thru perhaps a wall, ceiling, and a roof?
Keith Cress
It's based on IEEE 802.15.4 radio tech. (the ZigBee radio part):
http://www.rf4ce.org
Might be an opportunity for you to get a standard product?
Benta.
Freescale is a player in RF4CE and has offered their protocol for this use.
Go to Freescale's website and search for "Synkro".
Benta.
2.4 GHz is used with BlueTooth and WiFi, so your hands-on experience with these sorts of commercial products will indicate the range and performance you can expect. Obviously the antennas are a huge influence. But 30-feet should be easy, even with built-in sub-optimal antennas and a wall or two.
One thing to watch for is the requirement for leaving the link turned on (as opposed to instant on) and the effect of battery life and/or response time. But a BlueTooth headset for a mobile phone can last for days on a AAA battery.
You remark is correct for the headset, but that's because it is running at extremely low power (=short range). The OP wants up to 30 m, which is a different story altogether.
An 802.15.4 radio is much better, it is synchronized within few tens of milliseconds after sleep, which is what you need in a remote control.
Benta.
Glenn
Sick ISD-300 is an infrared bi directional comm device that communicates over 600 ft. used these on cranes
I have used Ethernet access points in transfer cars and cranes and this has been out for years. This would be an off the shelf access point that communicates to a wireless switch in the ceiling.
Are you reinventing the wheel? What is your niche market?
Reverse engineer other peoples stuff to get an idea and focus on an issue that has not been addressed.
wireless radio website these can get through steel easier than ethernet access points.
http://www.data-linc.com/srmfamily/srm6000.htm
Keith Cress
