FEA Tank Nozzles Geometry Generator
I am looking for a program that will automatically generate different tank nozzles based on input provided through say a "wizard" type of interface.
About 10 years ago I used a dos based program called ATAS (I think that was the name). This program would set up the nozzle node and element geometry; to be used in Algor, Ansys, or any other type of FEA software.
Does anyone recall this software?
RE: FEA Tank Nozzles Geometry Generator
Check with Paulin Research Group to see if that software will work for your purposes.  www.paulin.com or www.fepipe.com  I don't think it will export the mesh in to either of the software packages that you named, but it specializes in piping and pressure vessel components and has a product called "Nozzle Pro" if I remember correctly.
Right on GBor, NozzlePro is what mjsklar needs.
