material requirment?
which kind of material should i use for a Methanol Tank. Steel or stainless steel.?
RE: material requirment?
Is this for an above or below ground storage tank? In most cases, 304L stainless is used for piping and the tank itself to assure methanol purity and corrosion resistance.
My advice, is to review the information below and follow all necessary information information pertaining to safe handling and storage. Do your homework on this and review the sited codes and standards!
www.eere
Best Regards!
Plymouth Tube
S.
Corrosion Prevention & Corrosion Control
