What is the strength of A108 stud
What is the yield strength of A108 steel.  They are being used as Nelson Studs.  Thanks!
RE: What is the strength of A108 stud
THe latest AISC manual says that the tensile strength is 65 ksi, but does not specify the yield strength, as typically shear studs are defined based on the ultimate tensile strength.
Apparently my company has access to the actual code online, so I am good to go.  Thanks again!
